hrong4's avatar
hrong4
7 years ago
hi someone has offered this question before,and is there any answer for it?
Hi. I have the difficulty to understand the different of set_multicyle_path in system approach and skew approach(FPGA centric) in AN433 doc.
http://www.altera.com/literature/an/an433.pdf
the constraint for system centric approach(pg14),
set_multicycle_path -setup -end 0 -rise_from [get_clocks
data_clock] -rise_to [get_clocks output_clock]
set_multicycle_path -setup -end 0 -fall_from [get_clocks
data_clock] -fall_to [get_clocks output_clock]
the constraint for FPGA centric approach(pg26),
set_multicycle_path -hold -end -1 -rise_from [get_clocks
set_multicycle_path -hold -end -1 -fall_from [get_clocks
Questions:
Why does the FPGA centric approach have extra 2 set_multicyle_path -hold compare to system approach?
I update some as following:
since the two way have different set_false_path later in AN433,
-hold rise->fall,fall->rise for FPGA-centric;
-hold rise->rise,fall->fall for system-centric.
but all the constrain(multipath+false path) will introduce different desired setup/hold relationship.
  • My understanding is both of them should be the same after applied. Even though it does not put explicitly multicycle constraint for hold time in system centric approach, it should become -1 by default in the timing analysis if the setup multicycle =0. It always reduces by 1 from setup relationship.
  • sstrell's avatar
    sstrell
    FPGA-centric means it's contained within the device itself. As such, the hold analysis happens at the same edge at the boundary of the FPGA as opposed to 1 cycle earlier which is where it would be for the "downstream" device. I would stick with the system-centric approach. It's easier to understand and implement. You can see a good explanation of AN433 in the associated online trainings:
    https://www.intel.com/content/www/us/en/programmable/support/training/course/ocss1000.html
    https://www.intel.com/content/www/us/en/programmable/support/training/course/oddr1000.html
    #iwork4intel
    • hrong4's avatar
      hrong4
      sstrell,
      thanks for your response,but I still can not understand it.No matter fpga-centric or system-centric,the desired setup/hold relationship(data_clock and output_clock) should be the same.
