14 years agohelp to get gate circuit
Hi, I want to get the gate circuit which shows in the handwrite gate circuit
so I wrote the VHDL code below
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY memory_cell IS
PORT
( I :IN std_logic;----input bit
W :IN std_logic;-----write_enable
S :IN std_logic;----select_enable
clk :IN std_logic;
q :OUT std_logic------output bit
END memory_cell;
ARCHITECTURE structural OF memory_cell IS
SIGNAL J,K,J_g,K_g,Qa,Qb :std_logic;
ATTRIBUTE keep : boolean;
ATTRIBUTE keep OF J_g,K_g,Qa,Qb: SIGNAL IS true;
BEGIN
K <= NOT I AND W AND S;
J <= I AND W AND S;
K_g <= NOT (K AND clk AND Qa);
J_g <= NOT (J AND clk AND Qb);
Qa <= K_g NOR Qb;
Qb <= J_g NOR Qa;
q <= Qa;
END structural;
and I check the RTL Viewer, I get the image but not the same, How do I change the code to get the same circuit?1 Reply
There is one big problem with your implementation. Nobody can guaranty that a Flip-Flop or Latch build from discrete gates in a FPGA will work correctly. Then depending of the placement of the gates the routing can be very different especially for these crossing lines of the NOR gates. My advice to you is use the D-Flip-Flops in the FPGA to build the same functionality that your JK-Flip-Flop presents. The following code will implement your function:
You don't even use the toggle functionality of a JK-Fliop-Flop so you could implement it with a RS-Flip-Flop instead if you still plan to build it with discrete gates.LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY memory_cell IS PORT ( I : IN std_logic; ----input bit W : IN std_logic; -----write_enable S : IN std_logic; ----select_enable clk : IN std_logic; q : OUT std_logic ------output bit ); END ENTITY memory_cell; ARCHITECTURE structural OF memory_cell IS SIGNAL r : std_logic := '0'; BEGIN jk_ff: PROCESS (clk) IS BEGIN -- PROCESS jk_ff IF rising_edge(clk) THEN -- rising clock edge IF (W = '1' AND S = '1') THEN IF (I = '1') THEN -- J = '1' -- set register r <= '1'; ELSE -- K = '1' -- reset register r <= '0'; END IF; END IF; END IF; END PROCESS jk_ff; q <= r; END ARCHITECTURE structural;
