14 years agohelp to get gate circuit
Hi, I want to get the gate circuit which shows in the handwrite gate circuit so I wrote the VHDL code below
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY mem...
14 years agoHi,
There is one big problem with your implementation. Nobody can guaranty that a Flip-Flop or Latch build from discrete gates in a FPGA will work correctly. Then depending of the placement of the gates the routing can be very different especially for these crossing lines of the NOR gates. My advice to you is use the D-Flip-Flops in the FPGA to build the same functionality that your JK-Flip-Flop presents. The following code will implement your function:
LIBRARY ieee;
ENTITY memory_cell IS
PORT (
I : IN std_logic; ----input bit
W : IN std_logic; -----write_enable
S : IN std_logic; ----select_enable
clk : IN std_logic;
q : OUT std_logic ------output bit
END ENTITY memory_cell;
ARCHITECTURE structural OF memory_cell IS
SIGNAL r : std_logic := '0';
BEGIN
jk_ff: PROCESS (clk) IS
BEGIN -- PROCESS jk_ff
IF rising_edge(clk) THEN -- rising clock edge
IF (W = '1' AND S = '1') THEN
IF (I = '1') THEN -- J = '1' -- set register
r <= '1';
ELSE -- K = '1' -- reset register
r <= '0';
END IF;
END IF;
END IF;
END PROCESS jk_ff;
q <= r;
END ARCHITECTURE structural;
You don't even use the toggle functionality of a JK-Fliop-Flop so you could implement it with a RS-Flip-Flop instead if you still plan to build it with discrete gates.
