14 years ago
help please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....?
and use level select to select the frequency..this is the detail:
level 1-10 will select to frequency 1Hz to 10Hz..
i just can do till 1 Hz only but still dont know whether its correct or not....:(
tq....
    im trying to understand the code...when i put reset to low no result,but when i put high there is a change in the ouput waveform..but didint really divide the frequency...
    There might be problem in this code (possibly typing error) since the process is active only when reset = '1'.
    add else after it:
    if reset = '1' then
    else
