14 years agohelp please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. i just can do till 1 Hz o...
14 years agoim trying to understand the code...when i put reset to low no result,but when i put high there is a change in the ouput waveform..but didint really divide the frequency...
