17 years ago
Help me (Quartus 2)
:D Please!! Help me with this code. I do not know in reality that is incorrect. Thanks!
library ieee;
use ieee.std_logic_1164.all;
entity MUX_21 is
port(sel,gn: in std_logic;
A,B: in std_logic_vector(4 downto 1);
Y: out std_logic_vector(4 downto 1));
end MUX_21;
architecture sol of mux_21 is
signal f1,f2,f3,f4: std_logic;
begin
with sel select
f1<= a(1) when '0',
b(1) when others;
with sel select
f2<= a(2) when '0',
b(2) when others;
with sel select
f3<= a(3) when '0',
b(3) when others;
with sel select
f4<= a(4) when '0',
b(4) when others;
Y1<=f1 when gn='1' else '0';
Y2<=f2 when gn='1' else '0';
Y3<=f3 when gn='1' else '0';
Y4<=f4 when gn='1' else '0';
end sol;
Error (10482): VHDL error at MUX_21.vhd(30): object "Y1" is used but not declared
1 Reply
    Well the message says it... You declared a Y signal, but are trying to use Y1, that doesn't exist. I assume you meant Y(1)
