16 years ago
HELP ME about EP2C20Q240C8,PLEASE!
HI ALL
I'm using the cycloneII(EP2C20Q240C8).I want to know what the difference the pin 178 and the others.when i use the pin 178 as LVTTL output,it cannot output a wave (frequency about 25MHz when i use crystal about 50Mhz),but when i use other pin,they can do it.why??? THE wave mentioned above is that i see by the signal-tap. what can i do to solve it?
    thank you for your answer,but i have tried in two pcb.the first doubt can be excluded. the second doubt: i check the pin many times.
    but i have done another experiment, i use the pin178 to output other slow signal, it can do it.so??????
    There should be no reason why pin 178 wouldn't function as you want it to.
    I suspect you have a either a short between pin 178 and ground, or you are not looking at the right pin (because of a routing swap or so), or because in the logic project the signal is not placed on that pin.
    no,we just use it as normal IO,as the ADC's control clock,frequency about 25MHz .when we use other IO,it can work well,but when we use then pin178,it cannot output the right wave. i'm so confused!
