16 years agoHELP ME about EP2C20Q240C8,PLEASE!
HI ALL I'm using the cycloneII(EP2C20Q240C8).I want to know what the difference the pin 178 and the others.when i use the pin 178 as LVTTL output,it cannot output a wave (frequency about 25MHz whe...
16 years agoThere should be no reason why pin 178 wouldn't function as you want it to.
I suspect you have a either a short between pin 178 and ground, or you are not looking at the right pin (because of a routing swap or so), or because in the logic project the signal is not placed on that pin.
