16 years agoHELP ME about EP2C20Q240C8,PLEASE!
HI ALL I'm using the cycloneII(EP2C20Q240C8).I want to know what the difference the pin 178 and the others.when i use the pin 178 as LVTTL output,it cannot output a wave (frequency about 25MHz whe...
16 years agothank you for your answer,but i have tried in two pcb.the first doubt can be excluded. the second doubt: i check the pin many times.
but i have done another experiment, i use the pin178 to output other slow signal, it can do it.so??????
