antonto's avatar
antonto
5 years ago
Hello, im trying to simulate a module which has a pll,but i keep getting this error vsim-3033
This is the error message in modelsim
** Error: (vsim-3033) D:/altera askhseis/lora_test6/my_test_pll.v(72): Instantiation of 'altpll' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /topModule/my_test_pll_inst File: D:/altera askhseis/lora_test6/my_test_pll.v
# Searched libraries:
# D:/altera askhseis/lora_test6/simulation/modelsim/rtl_wor
I read something about some libraries missing but had no success. To be more specific i tried adding this libraby altera_lnsim_ver with this command vsim -L < library name > and got this message no design specified.
I could really use some help! Thanks you!
  • I see that you got the libraries, but you have to tell the tool where the ALTPLL library is, when you start the simulation. You command could look like:
    vsim -L altera_mf_ver work.<top_module>
    Regards.
  • Ash_R_Altera's avatar
    Ash_R_Altera
    Regards.
    • antonto's avatar
      antonto
      Thank you very much!!! It worked!!!
    Ash_R_Altera
    ALTPLL component can be found in altera_mf and altera_mf_ver libraries. Please include either of them based on the hdl language of the IP RTL files, using the -L option of vsim command.
    As @sstrell mentioned, it is not advisable to keep spaces in the path.
    • antonto's avatar
      antonto
      Hi again, sorry im still learning but i think i got those libraries as u can see in the picture below
      @sstrell And about the spaces in the path you mean this _? I tried without them but same result again! Sorry if the questions are silly! Thanks a lot!!
      ** Error: (vsim-3033) D:/altera askhseis/loratest8/mytestpll.v(72): Instantiation of 'altpll' failed. The design unit was not found.
      # Time: 0 ps Iteration: 0 Instance: /topModule/mytestpll_inst File: D:/altera askhseis/loratest8/mytestpll.v
      # D:/altera askhseis/loratest8/simulation/modelsim/rtl_work
  • sstrell's avatar
    sstrell
    I'm not sure if this is the issue or related to the issue, but you should not have any spaces in a path.
