Hello, im trying to simulate a module which has a pll,but i keep getting this error vsim-3033
- 5 years ago
I see that you got the libraries, but you have to tell the tool where the ALTPLL library is, when you start the simulation. You command could look like:
vsim -L altera_mf_ver work.<top_module>
Regards.
ALTPLL component can be found in altera_mf and altera_mf_ver libraries. Please include either of them based on the hdl language of the IP RTL files, using the -L option of vsim command.
As @sstrell mentioned, it is not advisable to keep spaces in the path.
Hi again, sorry im still learning but i think i got those libraries as u can see in the picture below
@sstrell And about the spaces in the path you mean this _? I tried without them but same result again! Sorry if the questions are silly! Thanks a lot!!
** Error: (vsim-3033) D:/altera askhseis/loratest8/mytestpll.v(72): Instantiation of 'altpll' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /topModule/mytestpll_inst File: D:/altera askhseis/loratest8/mytestpll.v
# Searched libraries:
# D:/altera askhseis/loratest8/simulation/modelsim/rtl_work
