16 years agoGXB_transceivers
hi,
I am using Quartus II 9.0 (SP2) and EP2AGX190FF35I5 device. I have basic doubts regarding ARRIA II GX Tranceivers, which i am listing below..... 1. How to enable the transceivers?whether i have to use any megawizad function? 2. When i am compiling quartus is giving a critical warning "Synopsys Constraints File" does not exist for timing model. 3. In report quartus is showing timing models as "preliminary. 4. Pin assignments i am assigning as PCML 1.5V....when compiling quartus is giving errors as: Error: Differential I/O output pin Tx_gxb[0] is assigned to a non differential location B31. However, it must be assigned to a differential output location Error: Differential I/O input pin Rx_gxb[0] is assigned to a non differential location C33. However, it must be assigned to a differential input location thanks Ramu1 Reply
1 - Transcievers are enabled by creating an instance of the altgxb megafunction in your design and connecting it to an appropriate transceiver pin.
2 - The "Synopsys Constraints File" (SDC) provides Quartus with the timing constraints for your design. You must create one: http://www.altera.com/support/software/timequest/sof-qts-timequest.html 3 - Timing models for Arria II GX are preliminary in Quartus 9.0. 4 - This error can occur if you've assigned the pin to be a differential I/O type but the pin is not actually used or connected to appropriate logic in your design (e.g. you haven't connected it to an altgxb instance). Jake
