16 years agoGXB_transceivers
hi, I am using Quartus II 9.0 (SP2) and EP2AGX190FF35I5 device. I have basic doubts regarding ARRIA II GX Tranceivers, which i am listing below..... 1. How to enable the transceivers?whe...
16 years ago1 - Transcievers are enabled by creating an instance of the altgxb megafunction in your design and connecting it to an appropriate transceiver pin.
2 - The "Synopsys Constraints File" (SDC) provides Quartus with the timing constraints for your design. You must create one: http://www.altera.com/support/software/timequest/sof-qts-timequest.html 3 - Timing models for Arria II GX are preliminary in Quartus 9.0. 4 - This error can occur if you've assigned the pin to be a differential I/O type but the pin is not actually used or connected to appropriate logic in your design (e.g. you haven't connected it to an altgxb instance). Jake
