SDavi9
6 months agoGTS Transceiver Compatibility
I have implemented a GTS Ethernet Intel FPGA Hard IP to interface to an external Optical transceiver. Is this compatible with : Optical Interface: 1000BASE-SX Multi-mode (850nm) ?
paveetirrasrie_Altera
5 months agoHello SDavi9
Yes, GTS Ethernet Hard IP can be used with an external 1000BASE‑SX optical transceiver, as long as you meet two conditions:
- The external module provides standard 1G SerDes line rates (1.25 Gbps).
- You interface through the transceiver’s standard serial differential pair (SFP/SFP+ type).
But overall, it should be compatible.
Pavee
5 months agoHello SDavi9,
As I've answered to your question, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you
