Ground noise when switching output
HI
When am switching any output Ground is bouncing 400mV 3 to 4 rings... is there any guidelines to reduce this
- Ash_R_Altera
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- ak6dn
How are you measuring that 400mV noise on your ground? What is the test lead setup into the oscilloscope input?
A less than optimal probing setup can induce false noise into your measurement.
You must be probing 'ground' with respect to 'ground', correct? But where are these two points located?
- Ash_R_Altera
Please let us know which FPGA device you are targeting to.
You may refer to documents available:
- AN-731: Simultaneous Switching Noise Guidelines for Intel Cyclone 10 LP, Cyclone IV, and Cyclone III Devices
- Device design guidelines
- AN 75: High-Speed Board Designs
- Pin connection guidelines
Regards.
- Karunakaran
Targeting to Max 10 10M08SAU169I7G
