Karunakaran
5 years agoGround noise when switching output
HI
When am switching any output Ground is bouncing 400mV 3 to 4 rings... is there any guidelines to reduce this
ak6dn
5 years agoHow are you measuring that 400mV noise on your ground? What is the test lead setup into the oscilloscope input?
A less than optimal probing setup can induce false noise into your measurement.
You must be probing 'ground' with respect to 'ground', correct? But where are these two points located?
