WShih8's avatar
WShih8
4 years ago
generate jbc file with command line
my condition is multi CPLD with a daisy chain mode.
and all CPLD is Max10 10M04SA
I have to try to generate jbc by quartus_cpf with multi-devices via the cdf file.
And the command line is:
quartus_cpf -c DaisyChain.cdf Programming.jbc -o background_programming=on
follow the Max10 configuration user guide and Quartus II script reference guide.
but in multi-chip daisy chain mode, I cannot DO_with_ISP mode successfully.
somebody knows how to gen the jbc file with DO_with_ISP.
my CPLD is Max10 10M04SAU324, Quartus programmer is 20.1
  • Hi,
    We noticed that you have request support from Intel Premier Support(IPS) account. Our team will continue to provide support from IPS and proceed to close this forum thread.
    Thank you.
    Aiman
  • WShih8's avatar
    WShih8
    Hi Aiman,
    The return messages are an illegal option.
    Quartus lite version only update to v21.1
  • Hi,
    Any error message shown?
    Can you try to program with the latest Quartus version such as version 22.1 or 22.2?
    Aiman
    • WShih8's avatar
      WShih8
      Upload the example pof_cdf.zip for you to reference.
      You can view the comparison results.
      Thru Programmer v18.1.0625 and v20.1.1.720 to generate JBC of around 249,205 bytes (~243KB), the CRC checksum is different.
      But if I try to use the command line "quartus_cpf.exe" to create JBC, the file size is up to 552,296byte (~539KB).
      And the file cannot use a USB dongle or Linux system to update the CPLD firmware.
      If I try to update CPLD firmware, my CPLD will immediately go down, and the daisy chain will crash directly.
      the command line is: (quartus_cpf.exe CDF_filename/pof_filename Output_JBC_filename -o background_programming=on)
      quartus_cpf CDF_10M04SAU324.cdf Output.jbc -o background_programming=on
      -o background_programming=on >> this is for Max10 ISP function enable option.
