generate jbc file with command line
Any error message shown?
Can you try to program with the latest Quartus version such as version 22.1 or 22.2?
Aiman
Upload the example pof_cdf.zip for you to reference.
You can view the comparison results.
Thru Programmer v18.1.0625 and v20.1.1.720 to generate JBC of around 249,205 bytes (~243KB), the CRC checksum is different.
But if I try to use the command line "quartus_cpf.exe" to create JBC, the file size is up to 552,296byte (~539KB).
And the file cannot use a USB dongle or Linux system to update the CPLD firmware.
If I try to update CPLD firmware, my CPLD will immediately go down, and the daisy chain will crash directly.
the command line is: (quartus_cpf.exe CDF_filename/pof_filename Output_JBC_filename -o background_programming=on)
quartus_cpf CDF_10M04SAU324.cdf Output.jbc -o background_programming=on
-o background_programming=on >> this is for Max10 ISP function enable option.
