15 years ago
Gates are not appeared in RTL viewer
Hey all,
I wrote the next code:
module increase_duration_1(in, clk, out, reset);
parameter LEN=10;
input in,clk, reset;
output out;
wire [LEN-1:0] or_out,path;
wire rstn;
or U2(or_out[0],path[0],path[1]);
assign out=path[LEN-1];
assign path[0]=in;
not not1(rstn,reset);
genvar i;
generate
for (i=0; i<LEN-1;i=i+1)
begin: shift_reg
dff u( .clk(clk),
.d(path),
.q(path[i+1]),
.clrn(rstn),
.prn(1'b1));
end
endgenerate
generate
for (i=1; i<len-1;i=i+1)
begin: or_connections
or u3 (or_out,or_out[i-1],path[i+1]);
end
endgenerate
endmodule
attached photo shows what I get in RTL viewer. why I don't see logic gates?
what am I doing wrong?
Thanks in advance
    --- Quote Start ---
    What is about the NOT gate.
    --- Quote End ---
    Look sharp, it has been simply absorbed by inverting the signal. But this doesn't mean much, because RTL is just a functional circuit. You have to review the synthesiszed netlist to see how the cicruit is implemented in LEs.
    Thank you very much, now I have OR gates.
    What is about the NOT gate. his output is connected to CLRN of DFFs and input to RESET. Why I don't see him?
    --- Quote Start ---
    Or gates generate or_out[i].
    --- Quote End ---
    or_out isn't an output of your design. out is the only one, wired to the DFF chain output.
    The or gates are ignored, because they don't generate any output signal in your design.
