15 years ago
FT245 in DE2 Board
In my DE2 board embedded usb blaster have a problem.(USB not detecting).So i suspect on FT chip and replaced it with new one.Now USB is detected shows unknown device :cry:
    I ll try and let you know. Actually board i have given board for rework.
    Hi all,
    I have the solution to my problem.
    I bought the DE1 board with the usb blaster
    the first time it was recognised as usb<->serial
    what i did:
    download FTprog form FTDI, whit this you can configuer the FTDI chip, also if it dousnt work in quartus.
    next you have to check that the vendor ID and Product id are the same as in the USBblaster .inf driver. this values were wrong.
    right settings:
    costum VID/PID : Costum VID/PID (not FTDI Default)
    Vendor ID : 09FB (not 0403)
    Product ID : 6001
    USB version nummer USB 2.0
    Bus Powered
    100mAmps
    USB remote Wake Up :off
    Pull Down :On
    Manufacturer : Altera (not FTDI)
    Product Description: USB-Blaster
    Serial number enabled: checked
    Auto Generate Serial No. Uncheched
    Serial Number 91d28401
    or Prefix : 91
    this worked for me (v91sp2)
    FIRST SAVE THE OLD CONTENT TO A XML FILE SO YOU CAN RESTORE THE SETTINGS
    I HOPE YOU GET IT UP
    Ya i have tested cables, its working fine. Its FT245BM it has external eeprom(93C46)
    Now i am suspecting on SN6550(Because its showing partial short of A & B pins of it).
    Can it work before? If did, change a usb cable or your PC port first.
    FT245B's config is in an external chip, and FT245R's config is build-in. If you replace a FT245R, you may restore the config.
    Unknown device is hardware problem. Check how did You solder it. If everything is correct, then it should show FTDI USB to serial bridge.
    Later, You will need to update the internal eeprom, VID/PID numbers.
