15 years agoFT245 in DE2 Board
Hi, In my DE2 board embedded usb blaster have a problem.(USB not detecting).So i suspect on FT chip and replaced it with new one.Now USB is detected shows unknown device :cry:
15 years agoHi all,
I have the solution to my problem. I bought the DE1 board with the usb blaster the first time it was recognised as usb<->serial what i did: download FTprog form FTDI, whit this you can configuer the FTDI chip, also if it dousnt work in quartus. next you have to check that the vendor ID and Product id are the same as in the USBblaster .inf driver. this values were wrong. right settings: costum VID/PID : Costum VID/PID (not FTDI Default) Vendor ID : 09FB (not 0403) Product ID : 6001 USB version nummer USB 2.0 Bus Powered 100mAmps USB remote Wake Up :off Pull Down :On Manufacturer : Altera (not FTDI) Product Description: USB-Blaster Serial number enabled: checked Auto Generate Serial No. Uncheched Serial Number 91d28401 or Prefix : 91 this worked for me (v91sp2) FIRST SAVE THE OLD CONTENT TO A XML FILE SO YOU CAN RESTORE THE SETTINGS I HOPE YOU GET IT UP
