15 years agoFT245 in DE2 Board
Hi, In my DE2 board embedded usb blaster have a problem.(USB not detecting).So i suspect on FT chip and replaced it with new one.Now USB is detected shows unknown device :cry:
15 years agoUnknown device is hardware problem. Check how did You solder it. If everything is correct, then it should show FTDI USB to serial bridge.
Later, You will need to update the internal eeprom, VID/PID numbers.
