15 years ago
Frequency of StratixIV
I'am so sorry if there are some mistakes in english.
I try to modify the frequency of StratixIV (used the PLL in SOPC builder), always, i obtained with the clock tools the same frequency 100Mhz. I see that's abnormal problem.
Any suggestion please :(.
    Hello Protocol Engineer,
    Think you very much for your reply.
    Of course in regenerated my SOPC in every change. Also the project.
    in the pll.sdc there are the two line "derive_pll_clocks -create_base_clocks" but this line is comment. This is the file pll.sdc
    # Uncommenting one of the following derive_pll_clocks lines# will instruct the TimeQuest Timing Analyzer to automatically# create derived clocks for all PLL outputs for all PLLs in a# Quartus design.
    # If the PLL inputs are constrained elsewhere, uncomment the# next line to automatically constrain all PLL output clocks.# derive_pll_clocks
    # If the PLL inputs are not constrained elsewhere, uncomment# the next line to automatically constrain all PLL input and# output clocks.# derive_pll_clocks -create_base_clocks
    Thanks for your helps
    Hello Aflouton,
    Can you post your timing constraints file?(*.sdc file) Does it have the following lines in it: derive_pll_clocks -create_base_clocks? Have you regenerated the SOPC project after you have modified the PLL? Have you recompiled the project after you have modified the PLL in SOPC builder?
    Ben
