15 years agoFrequency of StratixIV
Hi, I'am so sorry if there are some mistakes in english. I try to modify the frequency of StratixIV (used the PLL in SOPC builder), always, i obtained with the clock tools the same frequency ...
15 years agoHello Aflouton,
Can you post your timing constraints file?(*.sdc file) Does it have the following lines in it: derive_pll_clocks -create_base_clocks? Have you regenerated the SOPC project after you have modified the PLL? Have you recompiled the project after you have modified the PLL in SOPC builder? Thanks, Ben
