18 years agoFrequency Counter in Verilog?
Hi all, im trying to measure a squarewave frequency which is coming from a tacho.
The first implementation i tried used a known frequency and between rising edges of this frequency the rising edge of the input was counted. Once the know frequency gave a rising edge again the count was recorded then reset. Im not sure why but it didnt work!?!? The i went on to use a much quicker reference frequency and counted how many rising edges of this occured between rising edges of the input. the reference frequency is 10KHz. My coded didnt seem to simulate correctly!?!
module f_count(resetn,ref_clock,in_clock,f_measurment);
input resetn,ref_clock,in_clock;
output f_measurment;
reg f_measurment;
integer count;
always@(posedge ref_clock) // on rising edge of the reference 10KHz
begin
if(resetn) // if reset line is high do the operation
begin
count=count+1; // increase the count
end
else // if reset line is low
count=0; // then reset the count to zero
end
end
always@(posedge in_clock) // on rising edge of the input
begin
frequency=10000/count; // calculate the frequency based on the count value
count=0; // then reset the count to zero for the next measurment
end
endmodule
The simulation in Quartus II just didnt work as I wanted, the count did seem to make sence it reduced in frequency!?!?! Am i going about doing this all wrong?5 Replies
You failed to mention whether this module will be synthesized or if it is only for simulation. If it is for synthesis, it will not compile as your are breaking a few rules. In either case, give this a try. I didn't compile this but you get the idea
Your 10khz reference clock obviously doesn't allow you to measure a wide range of frequencies. You can really only measure frequencies between 1Hz and 5kHz and of course at higher frequencies, you'll have more error. Jakemodule f_count( input resetn, input ref_clock, input in_clock, output reg f_measurment ); reg in_clock_rsync; wire in_clock_rise; reg count; // Look for rising edge of in_clock assign in_clock_rise = ~in_clock_rsync & in_clock_rsync; // Resynchronize in_clock to ref_clock domain always @(posedge ref_clock) in_clock_rsync <= {in_clock_rsync,in_clock}; always @(posedge ref_clock or negedge resetn) if(!resetn) begin count <= 14'd0; // reset counter f_measurment <= 14'd0; // reset output end else begin count <= count + 14'd1; // increment counter by default if(in_clock_rise) begin count <= 14'd0; // reset counter f_measurment <= 10000 / count; // determine output end end endmodule - Altera_Forum
Hi there, the design will hopefully be implemented fully into a Cyclone II ( I have one of the Cyclone II eval boards).
The frequency range will be from a tacho mounted on a Yamaha R6 Motorbike engine which at maximum rev range will input 217 (approx) Hz square wave. Basically we want to monitor the revs remotely in the test chamber. Ill take a look at the example you posted and see how i get on...i only began using Verilog in September of last year so im still new to the syntax i guess :) - Altera_Forum
Let me know if you have questions.
If you monitor the frequency with an external system, maybe it is better to do the divide over there, and not in the fpga. Just send the counts over.
Stefaan - Altera_Forum
--- Quote Start ---
Jake --- Quote End --- the 3-bit wide in_clock_rsync is never used.. did you mean// Resynchronize in_clock to ref_clock domain always @(posedge ref_clock) in_clock_rsync <= {in_clock_rsync,in_clock}; endmodulealways @(posedge in_clock_rsync or negedge reset_n) if(!reset_n) begin count <= 32'd0; // reset counter f_measurment <= 32'd0; // reset output end ...
