18 years agoFrequency Counter in Verilog?
Hi all, im trying to measure a squarewave frequency which is coming from a tacho. The first implementation i tried used a known frequency and between rising edges of this frequency the rising e...
18 years agoYou failed to mention whether this module will be synthesized or if it is only for simulation. If it is for synthesis, it will not compile as your are breaking a few rules. In either case, give this a try. I didn't compile this but you get the idea
module f_count(
input resetn,
input ref_clock,
input in_clock,
output reg f_measurment
reg in_clock_rsync;
wire in_clock_rise;
reg count;
// Look for rising edge of in_clock
assign in_clock_rise = ~in_clock_rsync & in_clock_rsync;
// Resynchronize in_clock to ref_clock domain
always @(posedge ref_clock)
in_clock_rsync <= {in_clock_rsync,in_clock};
always @(posedge ref_clock or negedge resetn)
if(!resetn) begin
count <= 14'd0; // reset counter
f_measurment <= 14'd0; // reset output
end else begin
count <= count + 14'd1; // increment counter by default
if(in_clock_rise) begin
f_measurment <= 10000 / count; // determine output
end
end
endmodule
Your 10khz reference clock obviously doesn't allow you to measure a wide range of frequencies. You can really only measure frequencies between 1Hz and 5kHz and of course at higher frequencies, you'll have more error. Jake
