18 years agoFrequency Counter in Verilog?
Hi all, im trying to measure a squarewave frequency which is coming from a tacho. The first implementation i tried used a known frequency and between rising edges of this frequency the rising e...
18 years agoHi there, the design will hopefully be implemented fully into a Cyclone II ( I have one of the Cyclone II eval boards).
The frequency range will be from a tacho mounted on a Yamaha R6 Motorbike engine which at maximum rev range will input 217 (approx) Hz square wave. Basically we want to monitor the revs remotely in the test chamber. Ill take a look at the example you posted and see how i get on...i only began using Verilog in September of last year so im still new to the syntax i guess :)
