8 years ago
Fractional N PLL implimentation in IP possible on Cyclone V and max10?
Hi guys.
So I have a dedicated PLL chip that can phase lock an output clock of tens of Megahertz to an input clock of tens of Hertz, or million fold, using fractional N PLL.
Simple dividers will cause too much jitter at these multiplications, and divide by N PLL are necessary.
It's a great chip but I'm wondering if the same can be accomplished in an FPGA such as the Cyclone V or Max10 with the new Mega_Wizard. Let's say I want to phase lock a PPL output clock at 50MHz. to an input clock of 50Hz. - it looks like this kind of performance may be possible based on the information here: https://www.altera.com/products/fpga/features/stxv-fpll.html , but i'm not sure.
Thank for your help.
Cheers,
Bob
    I have a hard time imagining how you could use some simple analog off chip circuitry to raise the frequency of your clock from 50 Hz to 5MHz in order to use the PLL. I guess that you could have a succession of selective filters that would work on harmonics but I wouldn't call that solution simple, elegant, or low noise/jitter, if it can even work in the first place.
    If you already have a solution with an external chip that works well maybe you should keep it.
    It may be a stupid question but why do you need that in the first place? Couldn't you use a normal crystal oscillator and use logic to synchronize to the 50 Hz input instead? Do you really need that clock to be exactly 10^6 times the frequency of the input clock?
    --- Quote Start ---
    --- Quote End ---
    Thanks, Daixiwen. I'm sure you're right about just using the chip solution i have. Creating a soft IP version of the chip for FPGA is not my first task. Just something that occurred to me.
    Yes, i need to sync 10^6 for my application. I'm interested in your idea - use a normal crystal oscillator and use logic to synchronize. It sounds hopeful, but i'm not sure it will work for my application - can you elaborate or point me to a reference? I'm interested in all ideas. Thanks for your help.
    I need locked at the 10^6 input, but absolute phase not necessary - for every single cycle at 50Hz. i need 50M evenly spaced cycles. Phase locked also acceptable.
    Cheers,
    If you use a normal oscillator you could for example count the number of clock cycles during one full period on the 50Hz signal. Then you can use software to compensate any timing measurement/synchronization you do, based on that clock cycles count.
    But it really depends on your application and how accurate you need to be. If you really need those 10^6 cycles then I think your only solution is to use an external pll.
    This sounds like a video application to me, genlocking to a 50Hz source. I've used a Cypress CS2100/2300 for this in the past.
    --- Quote Start ---
    --- Quote End ---
    Yes, gj_leeson. I am using the 2300 version of that series. Great chip. I'm using it for master clock MCLK to codec 24bit 48KHz.
    --- Quote Start ---
    --- Quote End ---
    Thanks, Daixiwen. Is there a name for this type of circuit function?
