Kxyxl_vxly's avatar
Kxyxl_vxly
2 years ago
FPGA VERILOG
I am a final year student in mechatronics engineering . My final year project is to build a electronics voting system using DE10 Standard terasIC FPGA board in Quartus Verilog . The components that I need to use is AS608 Fingerprint sensor and 16X2 LCD Display with I2C module. Can You help me on this?
I tried to insert the pins in the pin planner but The pin is not found there . So, I tried to do the qsys in Quartus and it is showing error .I don't know what to do next.
  • Hi there, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
  • _AK6DN_'s avatar
    _AK6DN_
    Go here:
    https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081#contents
    And look at the documentation that TerASIC provides for that board.
    In particular, look at the RESOURCES tab, and at the DE10-Standard SystemBuilder tool you can download.
    It is a standalone windows program that can help you configure the I/O definition for the board resources/pinout
    that you can then edit/alter as necessary for your project definition.
    It will build a .qpf, .qsf, .sdc, and .v template files for you to start with.
    You also might look at some of the examples provided on the DE10-Standard CD-ROM image that is provided.
    It is very useful, if you don't already have that software and files you should.
    • Kxyxl_vxly's avatar
      Kxyxl_vxly
      Can u guide me to connect AS608 fingerprint sensor and 16X2 LCD Display with I2C Module to DE-10 Standard FPGA Board?I am confused about the pin location.Because when I run the pin planner it shows value entered is not a valid location.
