Kxyxl_vxly
2 years agoFPGA VERILOG
I am a final year student in mechatronics engineering . My final year project is to build a electronics voting system using DE10 Standard terasIC FPGA board in Quartus Verilog . The components that I...
sstrell
2 years agoYour system is connected up incorrectly. This is not how the clock source component is typically used.
But the easiest thing to do with start with a reference design (GHRD). The CD download for the board has example designs and is linked through Rocketboards: https://www.rocketboards.org/foswiki/Documentation/DE10Standard
Kxyxl_vxly
2 years agoCan u guide me to connect AS608 fingerprint sensor and 16X2 LCD Display with I2C Module to DE-10 Standard FPGA Board?I am confused about the pin location.Because when I run the pin planner it shows value entered is not a valid location.
