FabriceNs
4 months agoFPGA issue on electronic board
The FPGA is visible via the JTAG probe, and we can program firmware. It seems to run correctly. This is a good point. At this stage, we have tried to implement I2C accesses to configure a clock comp...
- 2 months ago
Background: HVIO stuck at high after configuration
Root Cause: RCOMP_GTS pin are left floating
Resolution: connect RCOMP_GTS to ground via external resistor (refer KDB)
Corrective Action: KDB filed
Farabi_Altera
4 months agoHello,
In your setup, do you have external pullups for the I2C signals?
regards,
Farabi
- FabriceNs4 months ago
Hi Farabi,
No there are n pullup for the I2C signal.
Do you know if this is a known issue?
Fabrice
