8 years ago
FPGA Development Board - strange shift operation behavior
My development board based on:
Cyclone IV EP4CE10E22C8N
Quartus: 17.0.0 Lite Edition
top-level entity code:
module led4_reg(clk, led);
parameter BASE_LED_SEQUENCE = 12'b000011101101;
input clk;
output  led;
reg  led;
reg  circle_count;
initial begin
    led = 0;
    count = 0;
    circle_count = 0;
    led <= ~led;
    $monitor($time, " led = %b count = %d", led, circle_count);
end
reg  count;
always @(posedge clk)
begin
    count <= count + 1;
    if (count == 1) begin
        count <= 0;
        circle_count <= circle_count + 1;
    end
    if (circle_count == 12)
        circle_count <= 0;
end
always @(circle_count)
begin
    case (circle_count)
        0: led <= BASE_LED_SEQUENCE;
        1,2,3,4: led <= (led << 1);
//        1:  led <= 12'b000111011010;
//        2:  led <= 12'b001110110100;
//        3:  led <= 12'b011101101000;
//        4:  led <= 12'b111011010000;
        5:  led <= 12'b110110100001;
        6:  led <= 12'b101101000011;
        7:  led <= 12'b011010000111;
        8:  led <= 12'b110100001110;
        9:  led <= 12'b101000011101;
        10: led <= 12'b010000111011;
        11: led <= 12'b100001110110;
        default: led <= 12'b000_111_111_111;
    endcase
end
endmodule
My test file:
`include "led4_reg.v"
module main();
reg clk;
wire  leds;
led4_reg reglight(clk, leds);
initial begin
    clk = 0;
    forever# 1 clk = ~clk;
end
initial# 160_000_000 $finish;
endmodule
And test results:
                 0 led = 000011101101 count =  0
            16777217 led = 000111011010 count =  1
            33554435 led = 001110110100 count =  2
            50331653 led = 011101101000 count =  3
            67108871 led = 111011010000 count =  4
            83886089 led = 110110100001 count =  5
           100663307 led = 101101000011 count =  6
           117440525 led = 011010000111 count =  7
           134217743 led = 110100001110 count =  8
           150994961 led = 101000011101 count =  9
But on the Dev Board LED for count item 1,2,3,4 always: 12'b000_000_000_000;
I don't understand why.
Additionally for some reason '0' - turn on light for LED. '1' - turn off for LED. Is it normal?
Any idea? ))
Thanks!
    You should ideally, store the previous value or initial value of the led in a register/flop. Then have it shifted out in the case. The default case may not work, but worth a try. You will understand what I mentioned if you look at how an always block will be executed.
    What you need to do is to latch in or register in the default value of the led (parameter) then use this value to shift left and get your corresponding outputs. For this to happen, the value of led register should be latched or stored, then used again in the case to update for the next case item.
    --- Quote Start ---
    There are a few issues in the code.
    --- Quote End ---
    Thank you for the response!
    Point 1,2 - thank you very much for remarks!
    3. I really can't understand why:
    1: led <= led; // will get previous value
    but
    1: led <= (led << 1); // can't get previous value
    Additionally, the default block never invoked.
    Am I understand correctly that I should implement simple latch for storing previous value?
    1. You cannot use initial blocks and $display tasks in RTL code for synthesis as these constructs are non-synthesizable . These are used only for simulation
    2. The code does not have a reset value or initial value. Use an asynchronous reset input and in the always block check for its negedge. When reset is asserted, initialize the count and output to '0'.
    3. The reason why led is always 0, is due to the fact that for the first case item (case 0) it will get the value from the parameter. For the next case items (case 1,2,3,4).. You are left shifting the value in the register which is always at 0. This is due to the fact that, after the case is hit, its value will get updated outside the always block. So the next time the code comes back to the case and hits the next one, the value of the led variable is 0. The previous value of led variable is not stored.
    You can accomplish this by modifying the default condition..
    default : led <= led;
    Although this will infer a latch that will store the last value of the register led.
    --- Quote Start ---
    Is your board an Altera/terasic dev board or a custom one based on Cyclone IV ? If its the Altera/terasic one, then most likely the LEDs are all active low , meaning, a writing a '0' will turn ON the LED and '1' will turn OFF the LED.
    --- Quote End ---
    Looks like custome Dev Board ZEOWAA A-C4E6E10.
    Main problem in the part:
    led <= (led << 1);
    if I use explicit form like:
    led <= (12'b000111011010 << 1);
    it work pretty well on Dev Board.
