10 years ago
FPGA Counter Catch Eight game(error 10476, error 10558)
hi,
im new to VHDL coding as im still learning the basics, i need to design a counter catch eight game and i have done the code but it shows and error and i am not able to solve it. it will be very helpful if anyone can help me wit this codes
http://www.alteraforum.com/forum/attachment.php?attachmentid=12644&stc=1
the error is shown in the picture.....
    So, 'Digit1_Output' is a 4-bit value. Which bit of that are you trying to connect your std_logic 'clock_output' to?
    I suggest you change
    Digit1_Output: out unsigned(3 downto 0)
    to
    Digit1_Output: out std_logic_vector(3 downto 0)
    At the top level connect a new 4-bit std_logic_vector signal in place of 'clock_output' and then connect 'clock_output' to whichever bit of 'Digit1_Output' you need.
    Cheers,
    Alex
    --- Quote Start ---
    You can attach any code to this post - I suggest the code for your 'Counter' module.
    Cheers,
    Alex
    --- Quote End ---
    ---counter
    library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.std_logic_arith.all;
    entity Counter is
    port(
    CLK: in std_logic;
    RST: in std_logic;
    end Counter;
    architecture Counter_arch of Counter is
    signal Digit1: unsigned(3 downto 0);
    begin
    process(CLK,RST)
    begin
    if RST = '0' then
    Digit1 <= (others=>'0');
    elsif rising_edge(CLK)then
    if Digit1 < 9 then
    Digit1 <= Digit1 + 1;
    else
    end if;
    end if;
    end process;
    Digit1_Output <= Digit1;
    end Counter_arch;
    Cheers,
    Alex
    --- Quote Start ---
    The 3rd port of your 'Counter' module is an 'unsigned' signal type and you're trying to connect 'clock_output', a 'std_logic' signal to it.
    Cheers,
    Alex
    --- Quote End ---
    hi mr alex,
    if i send u my full code will be able to able to fix it for me because as i know i already the sign these signals in the counter. Are u able to help pls?? if can pls drop me ur email, i'll send u my full code in notepad :)
    Cheers,
    Alex
