10 years agoFPGA Counter Catch Eight game(error 10476, error 10558)
hi, im new to VHDL coding as im still learning the basics, i need to design a counter catch eight game and i have done the code but it shows and error and i am not able to solve it. it will be ver...
10 years ago --- Quote Start --- You can attach any code to this post - I suggest the code for your 'Counter' module. Cheers, Alex --- Quote End --- ---counter library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; entity Counter is port( CLK: in std_logic; RST: in std_logic; Digit1_Output: out unsigned(3 downto 0) ); end Counter; architecture Counter_arch of Counter is signal Digit1: unsigned(3 downto 0); begin process(CLK,RST) begin if RST = '0' then Digit1 <= (others=>'0'); elsif rising_edge(CLK)then if Digit1 < 9 then Digit1 <= Digit1 + 1; else Digit1 <= (others=>'0'); end if; end if; end process; Digit1_Output <= Digit1; end Counter_arch;
