10 years agoFloating point addition in vhdl
Hii
I want to add 4 floating point no.what will be the result range.I am using library ieee_proposed; use ieee_proposed.fixed_pkg.all; this package.For example if I want to add two floating point no then the result range is C= A+ B -- range of C is (max(A'right ,B'right)+1 downto min (A'left ,B'left)) and it is working fine .But when I am doing C = A+B+D+E; What will be the new C range. If I am following the same as above I am getting an error "D:/214ee1411/vhdl codes/floatarith/mul_1test/fmul_1.vhd" Line 50: Expression has 11 elements ; expected 9 Please help me with this. Thank you11 Replies
--- Quote Start --- Yes, now you've added brackets, it will only need 2 extra bits. But a+b+c+d will break down into:
which does require 3 extra bits. --- Quote End --- I concur. But getting pedantic: each addition will generate an extra bit, so if n additions are concatenated (as you describe) the final addition delivers n additional bit. But the result only needs integer(ceil(log2(n))) extra bits so you can resize:result := (((a+b) + c) + d);signal a, b, c, d : ufixed(HH downto LL) ; constant NN : positive := 4; signal result : ufixed( HH + integer(ceil(log2(NN))) downto LL); result := resize((((a+b) + c) + d), HH + integer(ceil(log2(NN))), LL) ;
