10 years agoFloating point addition in vhdl
Hii I want to add 4 floating point no.what will be the result range.I am using library ieee_proposed; use ieee_proposed.fixed_pkg.all; this package.For example if I want to add two floating...
10 years ago --- Quote Start --- Yes, now you've added brackets, it will only need 2 extra bits. But a+b+c+d will break down into:
result := (((a+b) + c) + d);
which does require 3 extra bits. --- Quote End --- I concur. But getting pedantic: each addition will generate an extra bit, so if n additions are concatenated (as you describe) the final addition delivers n additional bit. But the result only needs integer(ceil(log2(n))) extra bits so you can resize:
signal a, b, c, d : ufixed(HH downto LL) ;
constant NN : positive := 4;
signal result : ufixed( HH + integer(ceil(log2(NN))) downto LL);
result := resize((((a+b) + c) + d), HH + integer(ceil(log2(NN))), LL) ;
