16 years ago
fixed-point tips
Hi
I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays). I have been asked to try and build a block that does some stuff rather more complicated than I am used to with real numbers... but of course the final block has to be synthesizable. Here is an example of a "phase diff block" that is needed.
Inputs:
I1, I2, Q1, Q2, A1, A2 (all 16-bit with values lying between -1 and +1)
cMode (Boolean)
kc (all 16-bit with values lying between 0 and +1)
Outputs:
Pd (16-bit with values lying between -1 and +1)
LD (Boolean)
The function to implement is something like:
Pd = (I1 * Q2 - I2 * Q1) / (A1 * A2)
ld = (1-kc) * ld + kc * (I1 * I2 + Q1 * Q2) / (A1 * A2)
If cMode = '0' THEN LD = 0
ELSIF ld > 0 THEN LD = 1 ELSE LD = 0
To be honest I don't really know where to start with how to define the data types and the equation for Pd. Any tips most welcome.
Many thanks, Kurt
    Hi All
    Many thanks for all your suggestions... being lazy I ended utilizing the recent IEEE fixed_pkg. For those interested, below is the code I ended-up with which seems to do the job OK (the functionality is a little different from my initial posting as the designer changed it):
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.ALL;
    USE IEEE.NUMERIC_STD.ALL;
    LIBRARY WORK;
    USE WORK.math_utility_pkg.ALL;
    USE WORK.fixed_pkg.ALL;
    ENTITY phase_diff IS
         PORT (
              clk : IN STD_LOGIC;
              i_I1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_Q1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_I2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_Q2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_A1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_A2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
              i_cMode : IN STD_LOGIC;
              i_kc : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
              o_phase_corr : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
              o_lock_detect : OUT STD_LOGIC;
              recipr : OUT STD_LOGIC_VECTOR (34 DOWNTO 0);
              a1a2 : OUT STD_LOGIC_VECTOR (33 DOWNTO 0)
    END ENTITY phase_diff ;
    ARCHITECTURE arch OF phase_diff IS
              SIGNAL s_phase_corr : SFIXED (0 DOWNTO -31);
              SIGNAL s_phase_corr_prev : SFIXED (0 DOWNTO -31);
              SIGNAL s_ld : STD_LOGIC;
              SIGNAL s_lock_fixed_prev : SFIXED (0 DOWNTO -15);
    BEGIN
         PROCESS(clk)
              VARIABLE v_I1 : SFIXED (0 DOWNTO -15);
              VARIABLE v_Q1 : SFIXED (0 DOWNTO -15);
              VARIABLE v_I2 : SFIXED (0 DOWNTO -15);
              VARIABLE v_Q2 : SFIXED (0 DOWNTO -15);
              VARIABLE v_A1_u : UFIXED (0 DOWNTO -15);
              VARIABLE v_A2_u : UFIXED (0 DOWNTO -15);
              VARIABLE v_A1 : SFIXED (0 DOWNTO -16);
              VARIABLE v_A2 : SFIXED (0 DOWNTO -16);
              VARIABLE v_kc : SFIXED (0 DOWNTO -31);
              VARIABLE v_recip : SFIXED (33 DOWNTO -1);
              VARIABLE v_pd_s1 : SFIXED (2 DOWNTO -32);
              VARIABLE v_pd_fixed : SFIXED (36 DOWNTO -33);
              VARIABLE v_pld_s1 : SFIXED (2 DOWNTO -32);
              VARIABLE v_pld_fixed : SFIXED (0 DOWNTO -15);
              VARIABLE v_lock_s1 : SFIXED (2 DOWNTO -46);
              VARIABLE v_lock_s2 : SFIXED (1 DOWNTO -46);
              VARIABLE v_lock_fixed : SFIXED (0 DOWNTO -15);
         BEGIN
              IF RISING_EDGE(clk) THEN
                   v_I1 := TO_SFIXED( i_I1, 0, -15 );
                   v_Q1 := TO_SFIXED( i_Q1, 0, -15 );
                   v_I2 := TO_SFIXED( i_I2, 0, -15 );
                   v_Q2 := TO_SFIXED( i_Q2, 0, -15 );
                   v_A1_u := TO_UFIXED( i_A1, 0, -15 );
                   v_A2_u := TO_UFIXED( i_A2, 0, -15 );
                   v_A1 := TO_SFIXED( v_A1_u );
                   v_A2 := TO_SFIXED( v_A2_u );
                   v_kc := TO_SFIXED( i_kc, 0, -31 );
                   a1a2 <= TO_SLV( RESIZE( v_A1 * v_A2, (2 * v_A1'HIGH) + 1, 2 * v_A1'LOW) ); -- 1 DOWNTO -32
                   v_recip := RESIZE( RECIPROCAL ( v_A1 * v_A2 ), (-2 * v_A1'LOW) + 1, -1 * ((2 * v_A1'HIGH) + 1) ); -- 33 DOWNTO -1
                   recipr <= TO_SLV( v_recip );
                   v_pd_s1 := RESIZE(( v_I1 * v_Q2 ) - ( v_I2 * v_Q1 ), (2 * v_A1'HIGH) + 2, 2 * v_A1'LOW );
                   v_pd_fixed := v_pd_s1 * v_recip; -- (I1Q2-I2Q1)/(A1A2)
                   v_pld_s1 := RESIZE(( v_I1 * v_I2 ) + ( v_Q1 * v_Q2 ), (2 * v_A1'HIGH) + 2, 2 * v_A1'LOW );
                   v_pld_fixed := RESIZE( v_pld_s1 * v_recip, 0, -15 ); -- (I1I2+Q1Q2)/(A1A2)
                   v_lock_s1 := ( 1 - v_kc ) * s_lock_fixed_prev;
                   v_lock_s2 := v_kc * v_pld_fixed;
                   v_lock_fixed := RESIZE( v_lock_s1 + v_lock_s2, 0, -15); -- (1-kc)*lock+kc*pld
                   s_lock_fixed_prev <= v_lock_fixed;
                   IF ((i_cMode = '1') AND (v_lock_fixed > TO_SFIXED(0.5, 0, -15))) THEN
                        s_ld <= '1';
                   ELSE
                        s_ld <= '0';
                   END IF;
                   IF (i_cMode = '0') THEN
                        s_phase_corr <= TO_SFIXED( 0, 0, -31 );
                   ELSE
                        s_phase_corr <= RESIZE( s_phase_corr_prev + (v_kc * v_pd_fixed), 0, - 31 );
                   END IF;
                   s_phase_corr_prev <= s_phase_corr;
              END IF;
         END PROCESS;
         o_phase_corr <= TO_SLV( s_phase_corr );
         o_lock_detect <= s_ld;
    END arch;
    There is some extra stuff in there just to help me with decoding, which I will remark out for the final version, but it seems to be passing testing at the moment.
    Many thanks, Kurt
    --- Quote Start ---
    fixed point is easy to deal with. Like integer arithmatic a 16bitx16 bit gives a 32 bit result, but now you havd 1.15 number. a 1.15 x 1.15 gives a 2.30 (2 bits magnitude, 30 bits fraction) result. remembering these rules makes using the ieee.numberic_std package possible because you can monitor which bits are magnitude, and which are fractional.
    so the following numbers, with range -1 to +1
    signal A, B : signed(15 downto 0); (1.15 number)
    signal C : signed(31 downto 0); (2.30 result)
    signal OP : signed(15 downto 0); (1.15 output (16 bits))
    c := A * B; --2 magnitude bits, 30 fractional bits
    OP := C(30 downto 15); --in range -1 to nearly 1
    (this is only possible if -1x-1 is not a possible input. If it is, you need to use the range (31 downto 16), and your result will be a 2.14 result, but you will lose 1 bit of accuracy. a 1.15 number only represents -1 to nealy 1, and cannot represent +1 itself, so an extra bit of magnitude is required)
    When multiplying any signed numbers, you will always have 2 sign bits as the MSBs unless you multiply the most negative number by itself, so assuming max neg x max neg is not possible, you can ignore the MSB and gain an extra bit of accuracy
    But now, life is alot easier
    All you need to do is use the new floatfixpkg from the IEEE:
    http://www.vhdl.org/fphdl/vhdl.html
    from here you can do stuff like this:
    signal A,B : sfixed(1 downto -14)
    signal C : sfixed(3 downto -28)
    signal D : sfixed(3 downto -12)
    process(clk)
    begin
      if rising_edge(clk)
        C <= A*B;
      end if
    end process;
    D <= c(d'range);
    Division is always going to be a bummer. But if you remember that A/B is actually just A * 1/B, and you can generate 1/B in software, all division problems are removed.
    --- Quote End ---
    I have a question regarding these libraries, do they work correctly if you were to use Altera's LPM modules like ALTMULT_ADD, ALTMULT_MAC, etc as their inputs?
    A std_logic_vector can be assigned to an sfixed signal by a conversion function, if it represents a fixed point number. But what do you mean with work correctly? If e.g. an overflow has occured in a LPM module, that don't provide saturation, it can't be recognized from the bit_vector. So the question is mainly, if the LPM module works correctly.
    --- Quote Start ---
    --- Quote End ---
    What I meant to ask is will the operations (multiply, add, etc) that a LPM/MegaFunction uses will give the correct results given an ufixed, or sfixed? Or just including the libraries will automatically use those functions for the fixed point types?
    Using these libraries has nothing to do with the LPM library. the LPM libraries are a separate thing altogether. Using the fixed_point libraries should give you much more reaadable and portable code, as well as making simulations much faster. The synthesisor should take the code and place multiplers/adders for you. The LPM library does not use the sfixed or ufixed types, so no you cannot input them into an LPMMULT and make it work, you have to type convert the values to std_logic_vector (which really is meant to have no meaning other than a collection of bits)
    So, where before you will have had:
    mult : altmult_add
    generic map (
      width_a  => 16,
      width_b  => 16,
    port map (
      clk       => clk,
      dataa   => a,
      datab   => b,
      result   => p,
    you can replace it with:
    mult_proc : process(clk)
    begin
      if rising_edge(clk) then
        p <= a*b;
      end if;
    end process;
    To be honest, this method has been around for years using the numeric_std package, just with the fixed package now it makes reading fixed point code that much easier.
    The Altera MegaFunctions are also inferred, when using arithmetic operators in HDL code, in addition, there are synthesis attributes to specify e.g. priority for hardware or software multiplier. They can be used for the design as a whole, for design units or part of them.
    So in most cases, you don't have to care for the usage of MegaFunctions respectively the optimal implementation of your code.
    Thank you guys for your answers. I was just unclear on whether or not I could use these types (sfixed, ufixed) with the LPM functions, or MegaCore functions so I don't have to reinvent the wheel. Also I am required to use the special DSP blocks (Stratix chips) for the application I am trying to develop and I was not sure whether this library would work with it.
