17 years agofixed-point tips
Hi I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays)....
17 years agoA std_logic_vector can be assigned to an sfixed signal by a conversion function, if it represents a fixed point number. But what do you mean with work correctly? If e.g. an overflow has occured in a LPM module, that don't provide saturation, it can't be recognized from the bit_vector. So the question is mainly, if the LPM module works correctly.
