17 years agofixed-point tips
Hi I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays)....
17 years agoHave a look through this document for the recommended coding styles to infer DSP or memory or anything else:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=code%20templates you should be able to replace signed/unsigned with ufixed and sfixed.
