17 years agofixed-point tips
Hi I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays)....
17 years agoHi All
Many thanks for all your suggestions... being lazy I ended utilizing the recent IEEE fixed_pkg. For those interested, below is the code I ended-up with which seems to do the job OK (the functionality is a little different from my initial posting as the designer changed it):
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
LIBRARY WORK;
USE WORK.math_utility_pkg.ALL;
USE WORK.fixed_pkg.ALL;
ENTITY phase_diff IS
PORT (
clk : IN STD_LOGIC;
i_I1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_Q1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_I2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_Q2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_A1 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_A2 : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
i_cMode : IN STD_LOGIC;
i_kc : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
o_phase_corr : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
o_lock_detect : OUT STD_LOGIC;
recipr : OUT STD_LOGIC_VECTOR (34 DOWNTO 0);
a1a2 : OUT STD_LOGIC_VECTOR (33 DOWNTO 0)
END ENTITY phase_diff ;
ARCHITECTURE arch OF phase_diff IS
SIGNAL s_phase_corr : SFIXED (0 DOWNTO -31);
SIGNAL s_phase_corr_prev : SFIXED (0 DOWNTO -31);
SIGNAL s_ld : STD_LOGIC;
SIGNAL s_lock_fixed_prev : SFIXED (0 DOWNTO -15);
BEGIN
PROCESS(clk)
VARIABLE v_I1 : SFIXED (0 DOWNTO -15);
VARIABLE v_Q1 : SFIXED (0 DOWNTO -15);
VARIABLE v_I2 : SFIXED (0 DOWNTO -15);
VARIABLE v_Q2 : SFIXED (0 DOWNTO -15);
VARIABLE v_A1_u : UFIXED (0 DOWNTO -15);
VARIABLE v_A2_u : UFIXED (0 DOWNTO -15);
VARIABLE v_A1 : SFIXED (0 DOWNTO -16);
VARIABLE v_A2 : SFIXED (0 DOWNTO -16);
VARIABLE v_kc : SFIXED (0 DOWNTO -31);
VARIABLE v_recip : SFIXED (33 DOWNTO -1);
VARIABLE v_pd_s1 : SFIXED (2 DOWNTO -32);
VARIABLE v_pd_fixed : SFIXED (36 DOWNTO -33);
VARIABLE v_pld_s1 : SFIXED (2 DOWNTO -32);
VARIABLE v_pld_fixed : SFIXED (0 DOWNTO -15);
VARIABLE v_lock_s1 : SFIXED (2 DOWNTO -46);
VARIABLE v_lock_s2 : SFIXED (1 DOWNTO -46);
VARIABLE v_lock_fixed : SFIXED (0 DOWNTO -15);
BEGIN
IF RISING_EDGE(clk) THEN
v_I1 := TO_SFIXED( i_I1, 0, -15 );
v_Q1 := TO_SFIXED( i_Q1, 0, -15 );
v_I2 := TO_SFIXED( i_I2, 0, -15 );
v_Q2 := TO_SFIXED( i_Q2, 0, -15 );
v_A1_u := TO_UFIXED( i_A1, 0, -15 );
v_A2_u := TO_UFIXED( i_A2, 0, -15 );
v_A1 := TO_SFIXED( v_A1_u );
v_A2 := TO_SFIXED( v_A2_u );
v_kc := TO_SFIXED( i_kc, 0, -31 );
a1a2 <= TO_SLV( RESIZE( v_A1 * v_A2, (2 * v_A1'HIGH) + 1, 2 * v_A1'LOW) ); -- 1 DOWNTO -32
v_recip := RESIZE( RECIPROCAL ( v_A1 * v_A2 ), (-2 * v_A1'LOW) + 1, -1 * ((2 * v_A1'HIGH) + 1) ); -- 33 DOWNTO -1
recipr <= TO_SLV( v_recip );
v_pd_s1 := RESIZE(( v_I1 * v_Q2 ) - ( v_I2 * v_Q1 ), (2 * v_A1'HIGH) + 2, 2 * v_A1'LOW );
v_pd_fixed := v_pd_s1 * v_recip; -- (I1Q2-I2Q1)/(A1A2)
v_pld_s1 := RESIZE(( v_I1 * v_I2 ) + ( v_Q1 * v_Q2 ), (2 * v_A1'HIGH) + 2, 2 * v_A1'LOW );
v_pld_fixed := RESIZE( v_pld_s1 * v_recip, 0, -15 ); -- (I1I2+Q1Q2)/(A1A2)
v_lock_s1 := ( 1 - v_kc ) * s_lock_fixed_prev;
v_lock_s2 := v_kc * v_pld_fixed;
v_lock_fixed := RESIZE( v_lock_s1 + v_lock_s2, 0, -15); -- (1-kc)*lock+kc*pld
s_lock_fixed_prev <= v_lock_fixed;
IF ((i_cMode = '1') AND (v_lock_fixed > TO_SFIXED(0.5, 0, -15))) THEN
s_ld <= '1';
ELSE
s_ld <= '0';
END IF;
IF (i_cMode = '0') THEN
s_phase_corr <= TO_SFIXED( 0, 0, -31 );
ELSE
s_phase_corr <= RESIZE( s_phase_corr_prev + (v_kc * v_pd_fixed), 0, - 31 );
END IF;
s_phase_corr_prev <= s_phase_corr;
END IF;
END PROCESS;
o_phase_corr <= TO_SLV( s_phase_corr );
o_lock_detect <= s_ld;
END arch;
There is some extra stuff in there just to help me with decoding, which I will remark out for the final version, but it seems to be passing testing at the moment. Many thanks, Kurt
