Fitter failed with "Unknown DQ mode"
QuartusII 13.1 Windows 64 bit
In the middle of Compile design, Fitter aborted with these signals, 100%
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Richard Tan
- RichardT_altera
Hi @remov_b4_flight ,
Do I understand correctly that changing the incorrect settings with the DQ_GROUP (mem_dqs[*] -> mem_dq) resolves the fatal error?
Richard Tan
- RichardT_altera
Does replacing the incorrect settings with DQ_GROUP resolve the fatal error?
Richard Tan
- RichardT_altera
I am not able to find a similar internal error in the database.
May I know which device you are using? Is it possible to upgrade the design to the latest Quartus version that supports your device? There is a chance that the internal error might have been fixed in a later Quartus release.
Quartus® Software Latest Version for Device Support:
If upgrading the design is not possible, please kindly share your design by archiving the project (Project > Archive Project) so that I can attempt to reproduce the error on our side.
FYI: For all cases involving Fatal Errors or Internal Errors, we need a design test case to reproduce the issue. Without being able to duplicate the error on our end, it becomes difficult to identify a workaround or solution.
Richard Tan
- DC-10
Hi all.
Project uses Stratix III device,13.1 is last version of Stratix III support.
I compared settings in Assignment editor with example project that generated by MegaCore wizard,
I found wrong settings with DQ_GROUP (mem_dqs[*] -> mem_dq).
Thank you.
- DC-10
After mem_dq[*] signals change group from "Memory Interface Data pin" to "DQ Group" ,Fitter progressed little but another Fitter signaled and failed.Internal Error: Sub-system: FSAC, File: /quartus/fitter/fsac/fsac_titan_dqs_config_op.cpp, Line: 989dqs_config_cell != 0Stack Trace:0x375b50: FSAC_TITAN_DQS_MGR::get_dq_pad_list_from_dqs_pad + 0x104800x376002: FSAC_TITAN_DQS_MGR::get_dq_pad_list_from_dqs_pad + 0x109320xa3ef: ftitan_execute + 0x7d6f0x4851d: FITCC_EXPERT::fitter_preparation + 0x20d0x4acf7: FITCC_EXPERT::invoke_fitter + 0x4170x28ef: ftitan_execute + 0x26f0xbab9: fmain_start + 0x7f90x1525: Legacy_fitter_Init + 0x4b50x2618: Legacy_fitter_Init + 0x15a80x2168: Legacy_fitter_Init + 0x10f80xf8a6: TclInvokeStringCommand + 0xc60x112a8: TclEvalObjvInternal + 0x3280x121b5: TclEvalEx + 0x8d50x12d48: TclEvalObjEx + 0x2d80x1abbd: Tcl_EvalObjCmd + 0xfd0x112a8: TclEvalObjvInternal + 0x3280x56917: TclExecuteByteCode + 0xe470xa2376: TclObjInterpProcCore + 0x760x112a8: TclEvalObjvInternal + 0x3280x56917: TclExecuteByteCode + 0xe470xa2376: TclObjInterpProcCore + 0x760x112a8: TclEvalObjvInternal + 0x3280x121b5: TclEvalEx + 0x8d50x7c117: Tcl_FSEvalFileEx + 0x1d70x7a626: Tcl_EvalFile + 0x360xc1ff: qexe_ipc_progress_bar_name + 0x12bf0x11dd6: qexe_get_command_line + 0x15560x150d5: qexe_run_tcl_option + 0x5850x1e03d: qcu_run_tcl_option + 0xb8d0x156ed: qexe_process_cmdline_arguments + 0x54d0x15851: qexe_standard_main + 0xa10xa7f8: msg_exe_fini + 0x580xaf3c: msg_exe_fini + 0x79c0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x1940xb8bf: msg_exe_main + 0x8f0x1259c: BaseThreadInitThunk + 0x1c0x5af77: RtlUserThreadStart + 0x27End-traceQuartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
