Fitter failed with "Unknown DQ mode"
I am not able to find a similar internal error in the database.
May I know which device you are using? Is it possible to upgrade the design to the latest Quartus version that supports your device? There is a chance that the internal error might have been fixed in a later Quartus release.
Quartus® Software Latest Version for Device Support:
If upgrading the design is not possible, please kindly share your design by archiving the project (Project > Archive Project) so that I can attempt to reproduce the error on our side.
FYI: For all cases involving Fatal Errors or Internal Errors, we need a design test case to reproduce the issue. Without being able to duplicate the error on our end, it becomes difficult to identify a workaround or solution.
Richard Tan
Hi all.
Project uses Stratix III device,13.1 is last version of Stratix III support.
I compared settings in Assignment editor with example project that generated by MegaCore wizard,
I found wrong settings with DQ_GROUP (mem_dqs[*] -> mem_dq).
Thank you.
