14 years ago
FIR Compiler Strange Output
I've just added an FIR Compiler to my design, for use as an antialiasing filter. The sampling frequency is 6.25kHz, and low-pass filter cutoff is 3kHz.
I've run a test signal through; a pure sine wave of 1kHz, but I'm getting a really bizarre output (images attached). Surely the output should be that same sine wave? Or is my understanding of FIR filters completely wrong?
    I simulated a fir based on the settings you showed in your screen captures and indeed the output format is the problem. You need to take the 12 MSBs.
    Try to use the 12 MSBs in your output. It looks like you are truncating the 8 MSBs right now. Also please try to run a clock rate a bit higher than the sample rate. That way you will have a bit better margins.
    /Boris
    Hi Boris,
    1. Signed Binary input
    2. UNSURE, I can't see anywhere in the Megafunction Parameters to explicitly define the output
    3. Clocked at 6.25kHz (Sampling Rate)
    4. No decimation or multichannel as far as I'm aware.
    I've attached screencaps of the Paramaters and Coefficients, for you to read at your leisure
    I have a few questions.
    1. What is your input set to? signed or unsigned?
    2. What is your output set to? signed or unsigned?
    3. What clock rate are you running?
    4. Are you doing any decimation or multichannel?
    /Boris
