14 years agoFIR Compiler Strange Output
I've just added an FIR Compiler to my design, for use as an antialiasing filter. The sampling frequency is 6.25kHz, and low-pass filter cutoff is 3kHz. I've run a test signal through; a pure s...
14 years agoTry to use the 12 MSBs in your output. It looks like you are truncating the 8 MSBs right now. Also please try to run a clock rate a bit higher than the sample rate. That way you will have a bit better margins.
/Boris
