14 years agoFIR Compiler Strange Output
I've just added an FIR Compiler to my design, for use as an antialiasing filter. The sampling frequency is 6.25kHz, and low-pass filter cutoff is 3kHz. I've run a test signal through; a pure s...
14 years agoI have a few questions.
1. What is your input set to? signed or unsigned? 2. What is your output set to? signed or unsigned? 3. What clock rate are you running? 4. Are you doing any decimation or multichannel? /Boris
