14 years agoFIR Compiler Strange Output
I've just added an FIR Compiler to my design, for use as an antialiasing filter. The sampling frequency is 6.25kHz, and low-pass filter cutoff is 3kHz. I've run a test signal through; a pure s...
14 years agoI simulated a fir based on the settings you showed in your screen captures and indeed the output format is the problem. You need to take the 12 MSBs.
