12 years agoFaster frequency in PWM
Hello all,
I'm trying to get the fastest frequency of PWM output to GPIO on DE1 board. I max out PLL to 450Mhz clock for PWM of 5000 steps and only get 80 or 90 kHz output. 1. My goal to get at least 200kHz output from PWM of 5000 or more in steps counting. 2. Is there a better PLL or faster FPGA like Stratix V or Cyclone V? 3. Is there a way in PWM to run faster? Thank, Sean6 Replies
Instead of using unreasonable high clock frequencies, I suggest fractional PWM methods.
--- Quote Start --- Instead of using unreasonable high clock frequencies, I suggest fractional PWM methods. --- Quote End --- Thank you for your help. How do I use fractional PWM methods. I have this simple code in Verilog duty_cycle [9:0] // 10 bits duty_cycle = 50; reg [31:0] counter = 0; always @(posedg clk) begin if (counter < 5000) counter <= counter + 1; else counter <= 0; pwm = duty_cycle >= counter; end - Altera_Forum
Generate multiple clocks, shifted in phase by different amounts. This will reduce the operating frequency of any one clock whilst maintaining the high 'data' rate you require.
So, you need 200kHz * 5000 = 1GHz. Four PLL clocks at 250MHz, shifted by 90 degrees each, could be used to generate the PWM modulation you require. This will require a combinatorial final output stage whose timing will be tricky to analyse. If the absolute step size is critical this may be a problem. The other way you could attack this is by using the transceivers present in Stratix parts. These will serialise data for you. They're (arguably) not intended to be use in such a way but that's not to say they can't be used in such a way. I'm not sure of the min/max operating frequencies the transceivers require but, in essence, this would allow you to operate at a greatly reduced clock frequency (e.g. 100MHz), present parallel data (e.g. 10-bit) and the hardware does the rest. Ensure you configure the transmitter to bypass the 8B/10B encoder. - Altera_Forum
Thanks a_x_h_75;
I already talked to my local Atlera FAE person. He suggested to use the same way transceivers that you mentioned about. Best wish Xmas 2013. Sean - Altera_Forum
Here's the basic idea of fractional PWM. The duty_cycle value is interpreted as n.m fixed point number. The integer part is compared with the pwm counter, m fractional bits are accumulated and overflow into the integer part. Please notice that the pwm method is also changed from natural to regular sampling.
Using phase shifted clocks or Gigabit transceivers is of course an option. Before spending the effort, I would ask which degree of signal purity is actually required or meaningful at all for the application? A case where the ns jitter of a fractional pwm may matter is e.g. class D audio. But it's impact in the signal band can be still effectively eliminated by using higher order sigma-delta modulators instead of the simple first order integrator in the example.wire duty_cycle reg duty_cycle_r; reg counter = 0; always @(posedg clk) begin if (counter < 5000) counter <= counter + 1; else begin duty_cycle_r <= duty_cycle + duty_cycle_r; counter <= 0; end pwm = duty_cycle_r >= counter; end - Altera_Forum
--- Quote Start --- Here's the basic idea of fractional PWM. The duty_cycle value is interpreted as n.m fixed point number. The integer part is compared with the pwm counter, m fractional bits are accumulated and overflow into the integer part. Please notice that the pwm method is also changed from natural to regular sampling.
Using phase shifted clocks or Gigabit transceivers is of course an option. Before spending the effort, I would ask which degree of signal purity is actually required or meaningful at all for the application? A case where the ns jitter of a fractional pwm may matter is e.g. class D audio. But it's impact in the signal band can be still effectively eliminated by using higher order sigma-delta modulators instead of the simple first order integrator in the example. --- Quote End --- Thanks FvM, My application will be Synchronous Bck Converter DC-DC. I'm also looking for example in Verilog so I can implement the code into FPGA. I have inputs from SPI to FPGA are V_in, V_out, I_set, and L (maybe enable too). So FPGA needs to do PWM (PWM_high, PWM_low). Do you know that Altera have example code that I can look at it? Best, Seanwire duty_cycle reg duty_cycle_r; reg counter = 0; always @(posedg clk) begin if (counter < 5000) counter <= counter + 1; else begin duty_cycle_r <= duty_cycle + duty_cycle_r; counter <= 0; end pwm = duty_cycle_r >= counter; end
