12 years agoFaster frequency in PWM
Hello all, I'm trying to get the fastest frequency of PWM output to GPIO on DE1 board. I max out PLL to 450Mhz clock for PWM of 5000 steps and only get 80 or 90 kHz output. 1. My goa...
12 years agoHere's the basic idea of fractional PWM. The duty_cycle value is interpreted as n.m fixed point number. The integer part is compared with the pwm counter, m fractional bits are accumulated and overflow into the integer part. Please notice that the pwm method is also changed from natural to regular sampling.
wire duty_cycle
reg duty_cycle_r;
reg counter = 0;
always @(posedg clk) begin
if (counter < 5000)
counter <= counter + 1;
else
begin
duty_cycle_r <= duty_cycle + duty_cycle_r;
counter <= 0;
end
pwm = duty_cycle_r >= counter;
end Using phase shifted clocks or Gigabit transceivers is of course an option. Before spending the effort, I would ask which degree of signal purity is actually required or meaningful at all for the application? A case where the ns jitter of a fractional pwm may matter is e.g. class D audio. But it's impact in the signal band can be still effectively eliminated by using higher order sigma-delta modulators instead of the simple first order integrator in the example.
