12 years agoFaster frequency in PWM
Hello all, I'm trying to get the fastest frequency of PWM output to GPIO on DE1 board. I max out PLL to 450Mhz clock for PWM of 5000 steps and only get 80 or 90 kHz output. 1. My goa...
12 years ago --- Quote Start --- Here's the basic idea of fractional PWM. The duty_cycle value is interpreted as n.m fixed point number. The integer part is compared with the pwm counter, m fractional bits are accumulated and overflow into the integer part. Please notice that the pwm method is also changed from natural to regular sampling.
wire duty_cycle
reg duty_cycle_r;
reg counter = 0;
always @(posedg clk) begin
if (counter < 5000)
counter <= counter + 1;
else
begin
duty_cycle_r <= duty_cycle + duty_cycle_r;
counter <= 0;
end
pwm = duty_cycle_r >= counter;
end Using phase shifted clocks or Gigabit transceivers is of course an option. Before spending the effort, I would ask which degree of signal purity is actually required or meaningful at all for the application? A case where the ns jitter of a fractional pwm may matter is e.g. class D audio. But it's impact in the signal band can be still effectively eliminated by using higher order sigma-delta modulators instead of the simple first order integrator in the example. --- Quote End --- Thanks FvM, My application will be Synchronous Bck Converter DC-DC. I'm also looking for example in Verilog so I can implement the code into FPGA. I have inputs from SPI to FPGA are V_in, V_out, I_set, and L (maybe enable too). So FPGA needs to do PWM (PWM_high, PWM_low). Do you know that Altera have example code that I can look at it? Best, Sean
