Failed Co simulation of a Example HLS design
Hi ,
I am have installed the intel Quartus prime 22.2 development suite in my system and tried to compile and test the HLS counter example design but it fails in the Co-simulation.
i++ counter.cpp -v -march=Arria10 -o test-fpga Target FPGA part name: 10AX115U1F45I1SG Target FPGA family name: Arria10 Target FPGA speed grade: -1 Analyzing counter.cpp for testbench generation Creating x86-64 testbench Analyzing counter.cpp for hardware generation Verifying version information in the included files. Expecting version 22.2.0.46.1 for all included files. Included files passed version check. Checked: none. Optimizing component(s) and generating Verilog files Generating cosimulation support Generating simulation files for components: count HLS simulation directory: /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/verification. HLS Elaborate verification testbench FAILED. See /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/debug.log for details. Error: Cosim testbench elaboration failed. Makefile:53: recipe for target 't
I have checked the debug .log ,
Debug log output:
/home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32 # -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32 # [exec] elab # vsim -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32 -L work -L work_lib -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_v er -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm -L twentynm_hssi -L twentynm_hip -L hls_sim_main_dpi_controller_10 -L main_dp i_controller -L hls_sim_component_dpi_controller_10 -L dpic_count -L avalon_conduit_fanout_10 -L count_cfan -L count_en_cfan -L hls_sim_clock_reset_10 -L clock_reset -L avalon_concatenate_singlebit_condui ts_10 -L cat_done -L count_internal_10 -L count -L cat_cwfsw -L avalon_split_multibit_conduit_10 -L sp_cstart -L altera_irq_mapper_2000 -L tb tb.tb # Start time: 10:26:00 on Oct 19,2022 # ** Fatal: ** Fatal: (vsim-3827) Could not compile 'export_tramp.so': cmd = '/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc -shared -fPIC -m32 -B/usr/lib32 -g -I. -I"/home/lsai_nikhil/intelFPGA_pro /19.3/modelsim_ase/include" -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_119 33/linuxpe_gcc-9.3.0/export_tramp.S"' # (vsim-50) A call to system(/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc -shared -fPIC -m32 -B/usr/lib32 -g -I. -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/include" -I"/home/lsai_nikhil/ intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.S" >'/tmp/quest atmp.j5QHxs' 2>&1) returned error code '1'. # The logfile contains the following messages: # /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: skipping incompatible /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x8 6_64-pc-linux-gnu/9.3.0/libgcc.a when searching for -lgcc # /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc # /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc_s # collect2: error: ld returned 1 exit status # # No such file or directory. (errno = ENOENT) # # # FATAL ERROR while loading design # ** Error: Error loading design # Executing ONERROR command at macro ./msim_compile.tcl line 15 # End time: 10:26:15 on Oct 19,2022, Elapsed time: 0:00:15
Can anyone help me to resolve the issue?
- hareesh
may i know your pc supporting 32 bit or 64 bit os?
- nikhl
Hi
My System is x86-64 bit , it supports 64 bit OS .
- hareesh
i am also facing problem with my compiler pls give me some time i will give the solution.
Thank you,
- hareesh
in my machine it's working fine. no problem. i am trying to duplicate your issue, so i need some information about your os
- which os are using
- quartus version
and once check HLS compatibility also
The Intel HLS Compiler Pro Edition Version 22.3 is compatible with the following Intel
Quartus Prime software:
• Intel Quartus Prime Pro Edition Version 22.3
• Intel Quartus Prime Pro Edition Version 22.2
• Intel Quartus Prime Pro Edition Version 22.1
• Intel Quartus Prime Pro Edition Version 17.1.1
• Intel Quartus Prime Standard Edition Version 21.1
The Intel HLS Compiler supports only Cyclone® V devices in Intel Quartus Prime
Standard Edition.
• Intel Quartus Prime Lite Edition Version 21.1
The Intel HLS Compiler supports only Cyclone V devices in Intel Quartus Prime LiteEdition .
- hareesh
follow the bellow document. execute in that way. and attached counter example design file try with that.
if you are facing same problem after that please download HLS compiler and install it and try same procedure.
- hareesh
did you tried what i shared steps?
please update the status of your issue
- nikhl
I tried the above steps, still it shows " HLS Elaborate verification testbench FAILED. "
- hareesh
As we discoursed in call please update your simulators and same steps.
- hareesh
Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
